newpcb
Newbie level 3
Hello,
I am working on a Pacific tv/dvd combi which has a no power fault, it was working ok then one day it stopped working and there was a burning smell.
I have found a burnt out component attached to a heat sink in the power section on the main board, I am not quite sure of this component having not worked on this type of equipment before. I thought it may be the 'hot' at first but it has 5 pins so it could well be a voltage regulator. All 'caps' seem to be ok.
Does anyone know what this component could be and what model/serial number it could be as well? The number on the board says N51.
Also, is the Pacific manufacturer similar to another company?
Thank you for any help given.
