harvie
Full Member level 1
Hello,
i've understood that it's possible to use P-channel MOSFET as rectifier. Eg:
https://www.youtube.com/watch?v=IrB-FPcv1Dc
But they wire Drain to power supply + and Source to load (-). However P-channel MOSFET is used as switch it's wired by Source to supply + and by Drain to load (-).
What's the difference? I know it's "unipolar" so it should not really matter, but there must be some difference, otherwise the pins wouldn't had different names.
Can i connect P-channel mosfet by Drain to + power, when using as switch? I'd like to use it for reverse voltage protection also, but if i wire it other way round it would not work because of parasitic diode... Will it loose performance if i'll do so?
I am designing low voltage cutoff circuit using P-MOS as switch and i think it would be cool if it could also prevent the reverse voltage...
