P-CAD PCB-sch question??
epp
Full Member level 5
Hi!
How can I update information between sch and pcb file.
I have next situation:
After I had finished sch I generated netlist and imported it into pcad pcb. When started manual routing I saw several mistakes within my part's pads&connections.
I need to change some part's pins definitions &connections in library and schematic and do not want to import netlist again and do routing again.
How to solve this problem?
Thanks.
Regards.
Try to use Eco option by enable it and open last schmatic that u extract net list from it ,make U'r changes then save this change in ECo file the open PCB and load this ECO file.
if U need just change PCB foot print U can change it in lib. and update it in PCB.
    epp
Hi
Modify the parts in library
Update schematic parts using force update command under utils menu.
Do the same for PCB. Now schematic PCB and lib are in sync.
To update changes use NetSync.exe in pcad installation folder
Thanks,
    epp
