Overflow in subtraction
Binome
Full Member level 3
Lyon, France
my problem is the overflow detection when subtracting:
There are two unsigned integer 4-bit numbers (a and b), so we have 0≦a,b≦15.
I want to subtract a-b, then -15≦a-b≦15.
This result is a signed integer 4-bit number then -8≦s≦7.
I want the operator to be able to detect an overflow. How should I build my circuit? (I have to use adders knowing a-b=a+not(b)+1).
Thanks.
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
When I worked with assembly language, I seem to remember I had to set the carry bit every time before doing a subtraction. If the carry bit is zero afterward, then a borrow occurs.
Ratch
Advanced Member level 1
Binome,
The CF will be set if there is a carry out or a borrow in of the most significant bit (MSB). Use a "full-subtractor" to implement this. Any good logic book should tell you how to build one.
Ratch
