[SOLVED] Overflow Error , RMS value shown wrong .
Raady Here
Full Member level 5
Full Member level 5
India
Hi ,
I am measuring AC Voltage and I am calculating rms value for ADC.
I have an array which is having 128 samples of my signal.
while squaring number i get error.
        unsigned long int calval=0;
	unsigned int loop;
	float adcbufval;
	for(loop=0;loop<128;loop++)
		printf("adcval %d = %d\t ",loop,adc_temp[loop]);
		calval = (adc_temp[loop])*(adc_temp[loop]);
		printf("\t %ld \n",calval);
               // calval += (adc_temp[loop])*(adc_temp[loop]);
               // adcbufval =(((sqrt(calval/samples))/4096)*OPV);
	       //printf("\n\r %f",adcbufval);
               //mesuredvoltage= adcbufval * fluke;        // fluke =249.62 as calculated
               // Printf("Volts = %f",measuredvolts);        // shown on UART.
output :
adcval 1 = 168 28224
adcval 2 = 32 1024
adcval 3 = -88 7744
adcval 4 = -211 44521 // sqr(211) 44521 , it fine here
adcval 5 = -314 33060 // sqr(314) 98596-65536 = 33060 instead of 98596.
adcval 6 = -416 41984
adcval 7 = -522 10340
adcval 8 = -655 35809
adcval 9 = -773 7705
adcval 10 = -889 3889
Though I defined 'calval' as unsigned long int (range 0-4,294,967,295), it get over flowed at 65536 value.
In normal c complier its working fine.
Any suggestions, help.
Edit :
using dsPIC30f5011 / MPLAB 8.8x
Regards,
Raady.
You missed to tell the type of adc_temp[]. I guess it's signed int (16-Bit), which pretty explaines the problem.
Refer to a C text book regarding implicite type conversion. The type of a product is defined by the largest type involved in the multiplication. You need to type cast one multiplicand to 32-bit before.
Yes i have used 'adc_temp' as signed int ,
I have done as you mentioned.
		printf("adcval %d = %d\t\t",loop,adc_temp[loop]);
		calval = ((unsigned long int)(adc_temp[loop])*(adc_temp[loop]));
		printf("\t\t\t %ld \n",calval);
The output shows fine for positive numbers but negative numbers take the 2's complement,
adcval 88 = -47 -6158175
adcval 89 = -151 -19769071
adcval 90 = -240 -31399680
adcval 91 = -331 -43275271
Let me know where I was actually wrong !
