now i am designing the over-current-protection function in LDO. i am confused about the stability of OCP loop, but not the main loop in LDO. why do we need to stable the OCP loop? and i am also puzzled with the function of OCP. is that only to prevent the great current in pass device when Vin is powered on?
how to realize the over-current-protection in design? i have used a current-mirror to realize it, but which destroy the stability of LDO loop. i want to know others how to realize it. pls. give me some help
The most accurate way would be to use a current mirror (N:1) ratio of power FET to sensor. You can then make the drains of the two transistors equal using an amplifier and generate a "reference gate voltage" on the sensor transistor. Use this voltage to clamp the gate of the power transistor when the current is exceeded.
