sulemanzp
Newbie level 5
Hi Experts,
Need your help for a circuit.
I made a circuit with CD4520 IC, the required output voltage is -8 volts but when load is attached to the circuit the voltage drops to approximately -3 volts (-2.286 Volts). So I found that ON resistance is 125 ohm so it is casing the voltage level drop.
So I replaced the IC with ADG1408 lower ON resistance 4.7 Ohm. Now the voltage drop is about 1 volts, but still the IC output current is 155 mA and 160 mA is required.
In below picture I gave the overview.
Experts kindly tell me a way to stable the voltage level with mux/switch or any other circuit enhancement.
Remember IN/OUT is a single line in which -8 volt signal sent and then received with -8 to -10 volt level. There is other circuit in parallel which handles the incoming -8 volt signal by enabling or disable the mux.
Thank you
Thank you
