MahmoudHassan
Full Member level 6
Hello
Dear all ,
I want to ask about a concept I want to understand, I read about output stages (Like the inverter one ) and I found that we can drive it in linear region to get maximum swing and that the input differential amplifier is designed to give the required gain.
But if we drive the output stage into linear I think that the signal will be distorted at it's maximu voltage as part of signal running at good gain of the output stage and other parts will be run at lower gain at maximum of the signal
so the output final signal will be distorted !! ?
Dear all ,
