Yes, becuase of the modulation scheme. EDGE use 8PSK which has a PAR of ~3dB. Given almost the same system, with the PA originally used for GSM, the output power for EDGE has to be ~3dB lower than GSM (Max power ~35dBm, which use GMSK with 0dB PAR)
