output of digital filter to analog signal
rameshrai
Full Member level 3
i have a digital filter in vhdl. i applied sinusoid signal to the filter through an ADC and wanted to convert back the filter output to analog but I get rectified output from DAC.
How to convert the digital filter output to analog signal with positive and negative swing?
thanks!
FvM
Super Moderator
Staff member
Bochum, Germany
First guess is, you are exceeding the ADC input voltage range. Or it's a problem of incompatible number coding schemes. More information needed.
rameshrai
Full Member level 3
thanks FvM, your first guess is right, there was problem with voltage setting on the ADC.
