Hello Guru's,
The circuit in question is a basic op-amp current-to-voltage converter with feedback resistor placed from output back to inverting terminal. signal current also connected to the inverting terminal and non-inverting terminal is connected to ground.
I remember back in school that if I have a voltage amplifier then I can express the output impedance as:
Zout = Zout,opamp(s) / (1 + beta(s)*A(s))
where Zout,opamp(s) is the open loop output impedance of the amp from the datasheet vs frequency.
beta(s) is the feedback factor which may or may not be frequency dependant and
A(s) open loop op-amp gain vs frequency.
Now I'm assuming I can use something like this for my transimpedance amplifier but I guess I'm not sure how to go about figuring out what beta(s) is for this particular circuit configuration. Would the model used for calculating noise voltage gain be used?
Thank you for any assistance.
Regards,
Tim
