Not unexpected when you use ideal op amps.Isn't it wonderful that a severely overloaded circuit works perfectly in a simulation?
For sure.Is it possible to burn an op amp by outputting too much current or voltage?
Depends on the used OPAMP. --> read it´s datasheet.If we short the output of an op amp what would happen?, would it run current until it burns out?, or it would just stop sourcing current at its Isc?. In other words, is it possible to burn an op amp by running it too hard?
