Output comes after few clock cycle
sarjumaharaj
Junior Member level 1
This is a program for shift register. I've used datapath and controller method to design the circuit. I got the output but the output comes after a delay. What could possibly be the error.
Here:
c0 c1
0 0 HOLD
0 1 SHIFT RIGHT
1 0 SHIFT LEFT
1 1 PARALLEL LOAD
sl sr pl : signals to shift left shift right and parallel load. If all the signals are 0 then the datapath should hold the data.
sli/sil -> serial input left ;
sri/sir -> serial input right ;
pil/pli -> parallel load input
One more thing I haven't you states for the controller just if statements. Could that be the reason for the output to be irratic. Both the comonents work fine individually. (i checked). If that's the reason can you explain why it is so?
MAIN MODULE
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity mainmoduleexam is
	port (clk , c0 , c1 , start : in std_logic ;
			pli : in std_logic_vector (4 downto 1);
			sli, sri : in std_logic ;
			po: out std_logic_vector (4 downto 1)
end mainmoduleexam;
architecture Behavioral of mainmoduleexam is
component datapath is
	port (clk , sl , sr, pl : in std_logic ;
			 sil , sir : in std_logic ;
			 pli: in std_logic_vector (4 downto 1);
			 pl0: out std_logic_vector (4 downto 1 )
end component;
component controller is
	port (clk , start , c0 ,c1  : in std_logic ;
			sl, sr , pl : out std_logic );
end component;
signal s_sl , s_sr , s_pl  : std_logic ;
begin
data : datapath port map(clk , s_sl , s_sr , s_pl , sli , sri , pli  , po);
control : controller port map ( clk,start , c0 ,c1, s_sl , s_sr , s_pl ) ;
end Behavioral;
CONTROLLER:
library ieee;
entity controller is
end controller;
architecture Behavioral of controller is
begin
process (clk )
begin
if  (start ='0') then
		sl <='0' ;
		sr <= '0' ;
		pl <= '0';
elsif(rising_edge (clk ) and start ='1' ) then
	if (c0 = '0' and c1 = '0' )then
		sl <='0' ;
		sr <= '0' ;
		pl <= '0';
	elsif (c0 ='1' and c1 = '0' ) then
		sl <='1';
		sr <='0';
		pl <='0';
	elsif (c0 = '0' and c1 = '1' ) then
		sl <='0';
		sr <='1';
		pl <='0';
	elsif (c0 = '1' and c1 ='1' ) then
		sl <='0';
		sr <='0';
		pl <= '1' ;
	end if ;
end if ;
end process ;
end Behavioral;
DATAPATH:
library IEEE;
entity datapath is
end datapath;
architecture Behavioral of datapath is
begin
process (clk )
variable memory : std_logic_vector (4 downto 1 ):= "0000" ;
begin
if (rising_edge (clk)) then
	if (sl ='0' and sr = '0' and pl ='0' ) then
		for i in 1 to 4 loop
			memory(i) := memory(i);
		end loop;
	elsif (sl = '1' ) then
		for i in 4 downto 2 loop
			memory(i) := memory (i -1 );
		end loop ;
		memory(1) := sil ;
	elsif ( sr = '1' ) then
		for i in 1 to 3 loop
			memory(i) :=memory (i +1);
		end loop;
		memory (4) := sir ;
	elsif ( pl = '1' ) then
		memory := pli  ;
	end if ;
pl0 <= memory ;
end if ;
end process ;
end Behavioral;
OUTPUT
Hi sarjumaharaj
It is not difficult to debug given you've loaded up your simulation as attached.
I spent two minutes to find the issue. But I would really prefer that you debug yourself first for a while before you ask this question. You are so close to the solution.
After putting more effort and if you still can't get it, reply this post again and I'll point it out.
Also, I highly recommend you follow some basic coding style like denting, single-line declaration for a signal, etc.
