out of memory in quartus 10 64-bit
ldhung
Member level 3
I use Quartus 10 64-bit, Windows 7, memory is 24GB, but still encountered Out of memory in module quartus_map.exe
Please help me how to solve this problem
Jack// ani
Advanced Member level 3
Interesting, so what kind of design you're trying to synthesize?
ldhung
Member level 3
I synthesize a memory, this is a part that encode 4096 bits to 12 bits (2^12) that I think the Quartus can not synthesize.
parameter NUM_WORDS = 4096;
parameter ADDR_WIDTH = 12;
reg [NUM_WORDS-1:0] addr;
reg [NUM_WORDS-1:0] temp, temp2;
reg [ADDR_WIDTH-1:0] maddr;
always @(posedge clk)
begin
if (~|temp) temp = addr;
for (i = NUM_WORDS-1; i >= 0; i = i - 1) if (temp==1'b1)
begin
maddr = i;
out = |(maddr);
end
temp[maddr]=1'b0;
end
Jack// ani
Well, only for loop with constant expression can be synthesized.
In your code decrement condition (i = i -1) is clearly not a constant, so this is where synthesis tool is breaking down...
ldhung
Member level 3
Oh, thank you. Can I use WHILE loop or another loop instead ?
