doha17
Newbie
Hello Everyone. I am trying to design a 1 GHz Oscillator using AT 41411. I am following 2 port negative oscillator design. I initially made sure to see negative resistance from both ports collector and Emitter after adding series feedback inductor to base. Then I terminated the collector port and emitter port still sees negative resistance. After that I tried adding the load network and do oscaprobe analysis however it never gives right solution. I have not touched any simulaion parameters. I am confused about where to place the oscaprobe and what changes to make for it to oscillate.
Terminated using inductor.
Port 1 input imedence. The load is added as Re_in/3 and -Xin.
