Oscillation problems in Multisim and Electronic WorkBench
electronicman
Member level 3
multisim wien bridge
I did many electronic oscillators Circuits Like RC Phase Shift ,Wien Bridge and
LC Oscillators in MultiSim And EWB ,but they did not work at all ,so What is
the problem of this and what i should do to solve this?
hock
Advanced Member level 2
India
oscillator multisim
multisim is a very bad simmulatos. it has many non convergance and accuracy issues.
keep away from it. it is a useless tool.
hock
papyaki
France
multisim lc
In general for simulated spice oscillators with capacitor or self, you need to specify the initial condition, like V = 0 for capacitors or I = 0 for selfs. Look at the parameter IC of these components.
E-design
Advanced Member level 5
The most common problem with simulating oscillators in Multisim is that the auto default initial time step is not set small enough by the program. Look under "Simulate, Interactive Simulation Settings, TSTEP" Set it manually small enough to handle the highest 1/f in your circuit. Example: If you expect 100MHz set to ≤ 1nS
FvM
Super Moderator
Staff member
Bochum, Germany
The other, as already mentioned below, is to set an initial condition different from equilibrium or skip the initial operation point aclculation in transisent analysis.
LvW
Germany
...or - as a third alternative - make one of the supply voltages time dependent (switch-on at t=0).
