[SOLVED] OrCAD urgent help.. Exporting netlist
lockman_akim
Advanced Member level 1
Malaysia
i have capturing the schematic by using Design Entry CIS..
some of my component is in company library server, some created by my self..
the problem is, when i exporting netlist, that have few warning
#1 Warning [ALG0016] Part Name "CAP_NP_CC0805_OV_DISCRETE_0.94MM_150-75038_20PF" is renamed to "CAP_NP_CC0805_OV_DISCRETE_0.94M".
#2 Warning [ALG0016] Part Name "CAP_POL_C250_RAD_POL_DISCRETE_11.4MM_150-78452_10UF" is renamed to "CAP_POL_C250_RAD_POL_DISCRETE_1".
#3 Warning [ALG0016] Part Name "CAP_NP_CC0805_OV_DISCRETE_1.4MM_150-77976_10UF" is renamed to "CAP_NP_CC0805_OV_DISCRETE_1.4MM".
#4 Warning [ALG0016] Part Name "DIODE_SOD323_IC_1.05MM_480-75133_1N4148WS" is renamed to "DIODE_SOD323_IC_1.05MM_480-7513".
and after import the netlist to the PCB editor, it jave 20 error of this
WARNING(SPMHNI-194): Symbol 'XTL2_HCM49' for device 'XTAL_XTL2_HCM49_IC_4.3MM_230-30' not found in PSMPATH or must be "dbdoctor"ed.
(just name of component change)
what is the factor of this problem? how to solve?
mfarooq1
Full Member level 2
Pakistan
hi,
i think the component names are too long.
try to rename any of the component to a shorter length.
Vamsi115
Junior Member level 2
Yes..
mfarooq was right try to rename the component with less than 30 characters.
Vamsi.
shipla
hi,
maybe .psm file is not present in the library.Open and save the footprint,this will create a .psm file and then try importing the netlist.
