hobbss
Member level 2
I am using OrCAD PCB Editor 16.3. My problem/question is partly software specific, and partly PCB layout in general.
I am attempting to create the footprint for a connector that will be carrying significant current loads (i.e., I ~ 16.5A). The connector is through hole, and has an odd pin with two "feet" (i.e., two drilled holes for each pin). For reference, the part number is: 42820-2212 (a Molex part, the data sheet and footprint can be referenced on Digikey's website).
So far, I have attempted to create a pad with two holes in it (rectangular for pin 1, and oblong for pin 2). I have created an antipad the same shape as the pad, with an additional 25mils all around.
My question pertains to the thermal relief: I have done some calculations, and determined that I need trace widths greater than an inch on internal layers to minimize temperature rise. Therefore, I would like to have no thermal relief on this component (given a hole dimension of 1/8", the thermal "relief" would actually just flood the pin). I am not worried about damaging the component, and my soldering iron can get hot enough to ensure a good solder joint even if the pins are flooded in an internal plane. However, PCB Editor complains that if a pad has an antipad defined, it MUST have a thermal relief shape defined as well. Is there any way around this? Or, is there a compelling reason why I really do need thermal relief? If so, how do I ensure that the "spokes" are sufficient to carry my required current?
---------- Post added at 10:43 ---------- Previous post was at 09:45 ----------
Follow up: Is there a way to change the spoke width for a thermal relief on only one component? I have attempted to edit the properties of the dynamic plane shape (use oversize spoke), but that updates it for all of the pads that touch this plane. I.e., a +5V power plane, with a bunch of IC's plugged in and one power connector. I would like to have large spokes on the power connector, and small spokes on the IC's.
