Orcad Layout to PCAD conversion...
Olxx
Member level 1
orcad to pcad
Does anyone know if it is possible to convert from Orcad Layout (*.max) to PCAD PDIF (*.pdf)?
maybe...
yes...
File->Export->Pcad PCB
you will get *.pdf file.
in Pcad -> Import.
you will get *.pcb.
As far as I understand I should do the following:
*.max->Layout->*.min->CAMCAD->*.pcb->PCAD->*.pdf
Is my understanding correct?
OrCAD(*.max) -> Protel -> PCAD (*.pcb) -> ...
mvm-e
Specctra can import both pcad and orcad files (*.pcb and *.max). Is it possible to import pcad files to orcad or orcad files to pcad via specctra.
Can camcad convert pcad to orcad, orcad to pcad in metric system or only in mils?
