OrCAD Layout pin numbers disappear
vistapoint
Member level 5
orcad layout pin disappeared
Suddently it doesn't display pin numbers of all components. How can I make it display pin numbers? I am sure OrCAD is the lousiest software in the world.
how to fix pin in orcad layout
If you press a layer select key such as "1" or "2", the pin numbers will mostly reappear.
If you have an early release of version 10, upgrade to 10.3 or 10.5. It won't fix the pin numbers, but at least the software is generally usable.
