orcad layout how to change hole size of the ped
ronydc
Full Member level 3
orcad layout hole
dear friends.
i learnt orcad- 9 but as i tried a lot i am unable to change ( increase ) the hole size of the peds.
if i select a capacitor, i get the hole size too small and i cant get that pcb through.
( example : --> for cap 100/25.. etc. etc..)
please some one explain me how we can change the hole size please.
thanks in advance.
rony.
changed hole size
first select the component then
goto > tool > footprint > a pop menu will come them right click on it >> goto properties >> padstick name >> give the required number >> for example 100R and click on down arrow key .
then click ok .
and you will find that you component pad size get increased
orcad diode in4007
this is correct.
but its very troublesum from orcad part.
example --> if we need to put a diode. and we select the footprint of a diode fom rhe list( if we have made it.)
but it is of normal diode ( IN4007)
THE real one we want is --> 5402 diode.
so at that time there is no other way to follow ur method ( increasing the size by ur way ) ..?
if you have the librery ( by names of the componants) please upload it so that my this problem will solve up to a great extent PLEASE.
THANKS,
RONY.
