Orcad/expedition importing
praveen_1383
Newbie level 1
Hi All,
This is praveen. Actually im finding an issue while importing the netlist from orcad capture to expedition.
I don't have much knowledge on expedition.I need to do some modification in the design. Presently the central library and layout file is in 7.8 version. And im using 7.9 version And im able to open the layout file in 7.9 version.
But while doing the project integration im getting an error as below
ERROR : Back annotation has been disabled.Cannot run back annotation.The disable back annotation option has been set in Project integration dialog.
WARNING : An error occurred updating the material/Process database from the central library
WARNING : OrCAD/Expedition interface ended with error :[13] Error while importing PDB information from PDB.hkp file ---see log file
Annotation is not being done since the schematics is done in orcad.
But there is a warning related to PDB (Part database)
Please can any body suggest on what needs to be done to fix the issue.
If i open the central library and just simply save the library in 7.9 version will the issue be fixed, since i guess this issue is because of version change.
Please provide ur valuable suggestion
Thanks and regards,
Praveen
manspcb
Newbie level 2
Hi All,
Thanks and regards,
Praveen
Hello Praveen,
I worked only with a Design Capture/Expedition combination but this is what I should do.
Look in your project file.
There is a BACKANNO entry what is the value there?
If it is "1" put it to "0"
If the problem is not solved let me know
Regards,
Mans
hobbyckts
Advanced Member level 1
Have you previously tried for doing the back annotation?
