Register Log in
Orcad 9.1 and drill plot
il_great
I want to print the pcb layers (Top and Bottom) that i have created with Orcad 9.1. I want to have the drills holes open with the real dimension of it but it only print the guide dimension of if ( with the option "keep drill hole open" checked )... Can someone help me???
Mazz
Advanced Member level 2
Try to export the drill file in gerber format and then you can see the real dimentions of holes.
Bye
Mazz
djolestojic
Member level 5
Select the drill layer in Orcad MAX file, and plot it into the DXF format.
Then, plot the DXF format (which preserves the real object dimensions) by using the Corel draw or Autocad.
Toggle Sidebar
