hqqh
Full Member level 4
Hello,
I use SP/ECC/TR/A V10.2 to route an design (4 routinglayer, 2planelayer) which was created with OR/C/AD LA/YO/UT 9.2x. SP/EC/CTR/A finish the routing process with 100% and no conflicts. But when I import the cct file in LAY/OU/T there are many unrouted wires. All this wires are connected to VDD or GND and should be connected by a micro via and a burried via. If I use normal via's through the hole board there is no problem but I loose many routing space. I have no idea.....
Thanks in advance
HQ
Thanks in advance
HQ
