Optocoupler output too low?
rexxar
Newbie level 1
Hey, I'm trying to make a MIDI/joystick port cable, with this schematic > **broken link removed**
I can send MIDI events to my keyboard just fine, but I can't receive. I didn't have the optocoupler in the schematic, so I pulled an LTV4N35 off of an old pci modem to use instead. What do I need to do to get this working?
Did you change the original diagram?
Have you check de polarity for D1 diode and the pinout for LTV4N35 in the circuit ?
1.
Did you verify current is flowing through the internal LED? Averaging 5-10 mA?
2.
Does your device need the same value, or a different value resistor at the transistor collector? A higher value is worth a try. Just in case there's reduced efficiency of operation in the optocoupler.
You need to verify that pin 6 (or your device's corresponding output pin) is alternating between hi and low V level.
3.
I see the schematic shows a pin (#7) connected to the base of the output transistor. It looks like a convenient place to apply a test signal to the base?
Does your device have any such pin? That would let you confirm operation in some way.
For instance, send positive supply V through a 3300 ohm resistor to the test pin. That should turn on the transistor sufficiently to pull the output low at pin 6 (or your optocoupler's corresponding output pin).
4.
Is there a chance your pin 15 (on the DB9) needs to be pulled high instead of low, and vice-versa? In other words, to reverse the phase?
There is a thing called datasheet. You'll realize, that 4N35 is specified with CTR > 100%, which is quite reasonable for a standard opto coupler, the original type is however a darlington OC which a much higher CTR. Unfortunately the circuit requires a high CTR of e.g. > 300 %. You possibly can fix the problem by changing R1 to 680R - 1K, but it also depends on the circuit behind the 15-pin MIDI port.
