T
treez
Hello,
Does the “dark current” of the TCLT1003 optocoupler increase as the opto ages or gets hot?…if so, by how much? (the datasheet doesn’t say)
TCLT 1003 datasheet
https://www.vishay.com/docs/83515/tclt1000.pdf
We are using the opto with the opto-transistor in common emitter connection, and it acts as a switch to turn ON/OFF a PFET……We are worried that if there is leakage current (dark current) going through the transistor when it should be off, then our PFET will get turned ON when it should not be ON.
TCLT 1003 datasheet
