Optocoupler between Microcontroller and Driving Circuit
pakkiboy
Member level 1
Member level 1
Jeddah, Saudi Arabia, Saudi Arabia
Dear Members, I am designing 2 KVa pure sine wave inverter system , using SG3525 to step up 24 Dc to 320 Dc , and then using IR2110 to make pure sine wave by SPWM signals from pic16f684 . I have a question that should I Use any optocoupler (like tlp250) between Microcontroller and Driving circuit or should I give signal directly to IR2110. (plz suggest so that will there be any problem when inductive load is connected ). plz help
Re: Optocpupler between Microcontroller and Driving Circuit
Using isolation is not necessary you can buffer the signal with c mos ic and send it to you H-bridge driver like HIP4081,IR2110,etc it works fine
yes pakikiboy,you can use CD4049 or4069 and you can also use transistors(NPN and PNP) to configured as buffer.
Check this simple arrangement using transistors and if you need he H-bridge driver circuit let me know
  • c0921-figure1.pdf
Bro , u mean that i should give output of controller ( PWM ) to this transistor and the output of transistor to IR2110 ( full bridge circuit ) ??? mine main aim is to isolate the controller circuit fully from high voltage crkt ... .. ( is there possible by this ) can u give me any idea regarding using CMOS ic ??? plz
I have understood the connection of transistor , but why should i connect them , I mean what is there purpose >???
if you want to use cmos ic then their will be no need of the transistors buffer you can use CD4069 instead,
for the transistors buffer is to to amplified the signal..
Usually PWM ic S3525 circuit is connected with battery so it needs isolation. This isolation is provided by the transformer. On the secondary side is 311V DC and 220V AC generator circuit which has mcu, does not require isolation. If you require isolation there too, hi speed optocouplers are required. A pulse driver transformer can also be used and then IR2110 will also be not required.
