Opto-isolator/ optocoupler for electric isolation in IC design.
imrankhanPNU
Member level 1
Member level 1
Hello everyone.
I came across while reading the opto-isolator technique used for electric isolation in embedded systems/ Integrated Circuits design that " Opto-isolator is not recommended for electric isolation in power applications IC's mainly due to its dV/dt sensitivity". So I would like to know:
1)How dV/dt sensitivity affects isolation?
2)Is dV/dt sensitivity the only reason to avoid optocoupler especially in power application IC/embedded systems?
3)Are there other limitations in optocoupler which can compel one to chose other isolation techniques?
Looking forward to your suggestions and guidance. Thanks.
danadakk
Advanced Member level 5
Is dV/dT the consideration for a Triac output optocoupler ? Eg. false triggering it ?
Are you trying to transfer across interface analog data or digital or switching power loads ?
Regards, Dana.
d123
Spain
Regarding question 3, I seem to recollect in one or two other threads that experienced, knowledgable members of this forum said that optocouplers degrade over time. Maybe someone else could confirm or deny that and explain why, if that's the case.
danadakk
Has to do with LED performance over time, simply google "optocoupler lifetime",
several articles, ap notes on the topic.
Regards, Dana.
