Opinions on Synopsys IC Compiler
mech
Anyone has used it? Is it good?
gliss
Advanced Member level 2
synopsys IC compiler
You can read customer testimonials on deepchip.com
Added after 38 seconds:
Are you thinking of buying it?
SkyHigh
Advanced Member level 1
Re: synopsys IC compiler
mech,
Synopsys IC Compiler or Synopsys ICC is new. Targetted primarily for the ASIC and SoC design market.
If you are only working with digital, it is OK with the basic and advanced editing toolboxes and check rules, constraints settings and process selection etc.
If you are also working with analog and RF, Cadence would be a better and more popular layout editor and it can also import Synopsys netlist generated from the Synopsys Design Compiler. The physical layout edited in Cadence can also be used by Synopsys Prime Time to perform post-layout simulation.
mech
Thanks guys,
I am a digital designer, but not responsible of purchasing tools. I am just curious about this tool and how it is positioned in synopsys tools suite.
debussy1765
Junior Member level 2
no, but basically, the operation adn process is same with dc
