74HCT05 hex inverter with open drain
I want to tied the drain through pull-up resistor to ~15V+
I have read the 74HCT05 spec sheet many times and I'm not sure if it rules it out....
I don't need much pull-up current ~20uA more than enough
should the output mosfet in the chip fail from this ? a drain-source breakdown presumably...
The goal is to buffer the control inputs to CD4066, which at 15V VDD need minimum VIH 8.4V
which need to be controlled from PIC outputs.....
if I can't use 74HCT05 then need to resort to using transistors+resistors which would use up
a lot of PCB real-estate
