operational amplifiers amplification level
Tracid
Member level 3
Neded, Slovakia
i would have one more question.
i got a connection like this one. i need the formula to get the Au(amplification level) of the amplifier.
does it change something in formula if i change the input polarities?
and could you give me some links where similar connections are explained?
Thank you very much again!
that circuit is a non-inverting amplifier, and the amplification formula,
A = (R1+R2)/R1
if you change the input polarity (inverting amplifier), the formula will be
A = Rf/Rin
but the circuit will be different.
So theres nothing to calculate with voltages? thanks very much!
This is a non-inverting amplifier having a gain of
A=(1+R2/R1)
if u change the polarity then this becomes a Inverting amplifier with a gain of
A= -R2/R1 -ve sign indicates the phase difference of 180 degree between input and output.
Keep in mind that change polarity such as feedback ramains negative if u will give feedback on +ve terminal then it behaves as a comparartor.
Ashish.chip : i hope you missed an ´R´ at your equation, because you wrote A= (1+R2/R1) and not (R1+R2)/R1. but thanks!
Ashish.chip is correct.
Non-inverting gain = (1+R2/R1)
Regards,
Pld4me
He was right.
(R1 + R2)/R1 = 1+R2/R1
