I'm using a microstrip quarter wave transformer with an open end connected to a short stub(part of impedance matching for a transistor).
As far as I know a wider microstrip(smaller Z0) for the transformer would result in better bandwidth. However I cannot understand why!
Can you help me with understanding the connection between the bandwidth and the impedance of the line?
I'm currently using "Microwave transistor amplifiers: analysis and design" by Gonzalez, and I don't have access to ieee or similar sites.
Any suggestions would be helpful.
Edit:
The open circuit stub trick (creating an RF short circuit that is DC-open) is often done with lower impedance lines than Z0. This effectively gives a wider bandwidth. An even better trick is to use a microstrip radial stub; it provides a low impedance, it doesn't suffer from a large distributed tee junction that a constant-width low-impedance stub would, and it just works better (trust us!)
When the Zo is lower then the tolerances of the line length becomes less critical. It happens because due to the formula Zo*j*tan(BL). So for large Zo the value of the expression will vary more with respect to the line length
