Note: This feature currently requires accessing the site using the built-in Safari browser.
Likely unless you can find such an op amp. The fix could be just adding a resistor in series with the input. Perhaps that could be added to the board with a cut of the input trace and soldering a small SMD resistor across the break.So, you're saying that in this case a redesign is the only option?
Don't know who IPC is but at the aerospace firm I worked, they got such patches approved to fly in military space satellites. Of course to meet the vibration requirements, the resistor was epoxied to the board since the solder pads were obviously below size specification.Wish I could do that - pretty sure it won't pass an IPC check with such a fix.
I was under the impression that the subject of this "pointless discussion" was just that.Pretty pointless discusson.
Design faults need to be fixed, either in a hardware patch (as far as applicable) or in a PCB redesign. That's it.
