barrybear
Full Member level 4
I have built some simple opamp occilator boxes for students to take readings from.
Square ,sine and triangle waves are generated with voltage outputs from200mv to 5 volts. frequencys from 40 hz to 20khz. they plug 20 volts dc in and an ossiloscope to the output all connections are with 4 mm plugs 2 for dc volts in and 2 for output to scope .
The problem is that often they plug the power in to the output connections and blow the opamp up .
Has anybody got any idea for an opamp that could take a little abuse .the chip that always blows is the AD 820AN single package opamp.
Thanks for any help
Thanks for any help
