jeffwjz
Junior Member level 1
I implemented an op-amp subtractor based on the following circuit
The op-amp is a TL071 and supplied with +-15V. The Vref is obtained by connecting the common end of a potentiometer to the input and the other two terminals of the potentiometer are connected to +15V and ground. So I can adjust the value of Vref from 0 to +15V.
The problem is: when I change the value of Vin, the Vref also changes. Why is this happening?
Thank you very much.
