hithesh123
Full Member level 6
What is the output of the op amp when either Vcc or Vee is not connected.
I simulated this and got Vsat. +Vsat when Vee was missing and -Vsat when Vcc was missing.
But I don't know why the output saturates to +Vsat, even in a inverting configuration. Shouldn't it go to ground, since the output equation is Vout = -Rf/R1 (Vin)
Same output as above, when Vin is zero. Op amp in question is TLE2061
Can some one tell me from the equivalent diagram in the datasheet, which transistors will be turned ON at the output stage?
