Op-amp Diode Rectifier Circuit
adnan012
Advanced Member level 1
Hi, Can anyone explain the working principle of the circuit given in the attached file.
Regards
  • Precision Rectifier Circuit for CT Signal Conditioning.pdf
KlausST
Super Moderator
Staff member
it´s well explained in the document.
So why do you ask?
What exactely do you want to know?
Klaus
adnan012
How positive cycle and negative cycles are rectified?
d123
Advanced Member level 5
Spain
I think it's like the 4-diode rectifier principle, positive signal gets through, negative can't get through diode. Diode conducts on positive half of wave, doesn't conduct on negative half of wave.
Nice article that may help to explain rectification circuits:
https://sound.whsites.net/appnotes/an001.htm
BradtheRad
Super Moderator
Staff member
Minneapolis, Minnesota, USA
This arrangement is a way to subtract the diode drop. It acts closer to an ideal diode. This is because it takes feedback voltage from the furthest end of the diode (rather than directly from the output as in opamp circuits we are used to seeing).
crutschow
Colorado USA Zulu -7
By having the diode inside the op amp negative feedback loop, the diodes forward drop is reduced by the open loop gain of the op amp.
Since most op amps have an open-loop gain of a 100,000 or more, the typical 0.7V diode forward drop is reduced to below 10µV (negligible for most practical purposes).
