Op-amp datasheet confusion (output voltage swing)
allanvv
USA
For the AD8270:
Is it just me or do the table and figure contradict each other?
RCinFLA
Advanced Member level 2
I don't see any contradiction. Looks like it needs about 1 volt overhead (you can only drive it to within 1 volt of either supply rail).
The figure deals with common mode offset from centering between supply rails. It means you lose some dynamic range the greater the common mode input voltage is away from centered on supply rails.
allanvv
USA
Oh, I see. I was interpreting the figure wrong. The output voltage is the common mode output voltage for common mode input voltages. For some reason I thought the hexagon represented the range of possible output voltages.
allanvv
USA
Actually, I still don't understand what the figure is saying.
For a common-mode input voltage of 0V, is the figure saying that the output voltage can be between -2.5V and 2.5V?
FvM
Super Moderator
Staff member
Bochum, Germany
Yes. The range isn't limited by the swing of the output stage rather than the input voltage range of the (internal) OP. In so far the question title is missing the point.
