Register Log in
op-amp circuit schematic
perado
Full Member level 2
Hi
the attached schematic is an op-amp, which input pin is + and which one is - ?
keith1200rs
Super Moderator
Staff member
Yorkshire, UK
Follow the signals through the circuit. If V2 goes lower, what happens to the output? It also goes lower. Therefore it is non-inverting.
Keith.
Reactions: perado
    perado
leo_o2
China
When V2 is higher than V1, it leads to more current flowing thru the left branch and more current flowing thru M4. It will pull high Vo
Reactions: perado
    perado
perado
Full Member level 2
thanks for your replies
now I want to design an op-amp with the structure that I attached but I dont know I should start from where, can anybody help me? wich parameters are important in op-amp desin? Is this structure a good one?
leo_o2
China
In fact, it depends on your application.
Generally, opamp spec are: input range, output range, min supply voltage, current consumption, slew rate, noise, offset, gain, phase margin, bandwidth, PSRR, CMRR.
Reactions: perado
    perado
perado
Full Member level 2
I want to use op-amp in this circuit :
dgnani
Advanced Member level 1
USA
The opAmp you are planning to use will have to sink current from the RL resistor, what you trying to use is really an OTA, which usually handles only capacitive loads or very small currents. Unless RL is very large, you should probably add a buffer stage.
leo_o2
China
I think you should consider these specs at the least:
stability(loop gain, phase margin, bandwidth), driving capability, input voltage range, slew rate, offset influence.
perado
Full Member level 2
hi
which structure is good for use at this circuit?
dgnani
USA
a two stage Miller opamp seems a better fit but it really depends on the signal coming from Zin and its impedance (looking in the opposite direction to the arrow in your schematic), basically what determines the load of the op amp
As simple way to verify you have the right specs for your op amp (DC gain, bandwidth, output resistance, slew rate,...) is to implement it first as an ideal op amp with the specs you are planning to target in the actual design; until the ideal design works there is no reason to start designing the real thing
Toggle Sidebar
