One question about system verilog `__LINE__ define
xiaojigao
Newbie level 6
Newbie level 6
China
There is a compiler derective in system verilog -- `__LINE__, it will expands to the current input line number. But I find it will return current line number -1.
For example, in below code(the left is line number):
1 initial begin
2 signal_a = 0;
3 signal_b = 1;
4 $display("current line is: %0d",`__LINE__);
5 end
When I run this code using ncsim, it will output:
current line is: 3
It's so strange, I think it should output "current line is: 4", because obviously this line number is 4, but not 3.
Can somebody tell me why?
Thanks a lot!
For example, I compile below file using Cadence irun:
1 module top;
2 initial begin
3 $display(" current line: %0d",`__LINE__);
4 $finish;
5 end
6 endmodule
This file is top.sv, I compile it using below simple way:
irun top.sv
Then it outputs result:
current line: 2
My irun version is 12.20-s014.
