xzp
Member level 2
Hi, thanks for reading.
Currently, I am encountering a simulation problem.
I want to simulate a resistor with a resistance that is frequency dependance. Because of the noise limitation, I can not use the normal R device in Pspice. Instead I use G device (Voltage --> current) in the analog library. For constant value of resistance, it is easily be achieve by setting the "Gain" in the properties. however, the resistance of the resistor is 5Meg/f where f is the frequency.
So how to set the gain or other parameter to simulate this frequency dependance resistor by using G device?
I appreciate your help much!
Added after 48 minutes:
I appreciate you guys help!
