on air studder audio mixer 2000m2
waqasraheel
Newbie level 5
i need some help
i m using the sound mixer which name is "ON AIR STUDDER 2000M2" in this the problem which i m facing is that it lost all the memory which i assigned to input of channels on the manual it is written that it happen due weak battery and instruct to replace the battery when i want to locate the battery in the board then i could not find it i want to know that where the battery is installed in it i will be very thankful to you
actually i cant find it where it is installed please tell me where it is installed in the PCB board
I cannot link to the pdf but if you search Google for 'studer 2000m2 mixer battery replacing' (spell Studer correctly) you should get a link with a pdf with instructions.
Keith
actually there is no information regarding this in the manual so anyone can help me
