hi,
i design a telescopic cascode OPAMP with SC-CMFB, but .tran simulation result shows that there is offset about 20mv between output voltage and Vcmo(1.65v). the curve is not flat . what's the problem with this?thanks!
and how to simulate the settling time of one full differential OPAMP with SC-CMFB?when i simulate it in closed loop as the sample-hold environment, the sample-hold clock effects the settling time.how can i simulate it without the clock effection?
Regards!
