KD494
Member level 5
- Joined
- Jun 24, 2015
- Messages
- 83
- Helped
- 13
- Reputation
- 26
- Reaction score
- 13
- Trophy points
- 1,288
- Location
- Boston, MA
- Activity points
- 2,058
Hey all,
So I'm working on a signal chain using two stages of fully differential amplifiers. Essentially the circuit looks like two stages on the picture below one after another.
The part I'm using, pretty much the only one I can find with the right characteristics, has a maximum differential voltage offset of +/-3.5mV. The combined gain of the two stages will be around 1000 in the worst case scenario. Operating around a midsupply cm voltage of 1.65V this should have me hitting the rails. In the past when dealing with single ended circuits I have been able to add a summing node with an appropriate DC cancellation voltage in between the two stages to eliminate the offset. However, without the virtual ground, I don't see how a fully differential inverting stage can implement a summing junction. I'm wondering if there is a similar scheme I can use here, implementing a DAC or some controlled voltage source in a feedback loop to keep my signal centered around the common mode voltage I desire. Thanks in advance.
