T
treez
Hello,
Do you see any problems with this (non-optocoupler based) isolated feedback method for offline SMPS’s? Why does nobody do it like this?
The attached schematic shows what surely must be a total revolution in isolated feedback for offline SMPS’s? –It allows the feedback signal to cross the isolation boundary without recourse to an optocoupler. (instead , a digital isolator is used, freeing the engineer from the opto with all its inherent problems such as poor parameter tolerance and ageing problems )
With the error amplifier on the secondary side, the feedback signal takes the form of a variable duty cycle square wave, produced by a simple PWM controller IC. This is passed across the isolation boundary by the digital isolator. On the primary side, the PWM error signal is filtered and then fed to the PWM comparator in the primary side PWM controller IC. –Hence the SMPS output is regulated
There is also the LTspice simulation attached.
What’s wrong with this way of doing it?
Why does nobody do this?
SI8410 Digital isolator datasheet:
http://www.silabs.com/Support Documents/TechnicalDocs/si8410.pdf
LT1243 datasheet:
http://cds.linear.com/docs/en/datasheet/1241fa.pdf
LT1243 datasheet:
