Are you all familiar with a website called www.mathworks.com?, where there is a section of File Exchange, where you have Matlab codes for various schemes, shared by the members of the website
in this link you will find the following:
Tutorials
* Orthogonal Frequency Division Multiplexing (OFDM) (pdf, 422 kb)
* ECE4606: Wireless Communications
o Classifications of Wireless Systems (pdf, 57 kb)
o Quick Overview of Channel Impairments (pdf, 125 kb)
o History of Mobile Communications (pdf, 56 kb)
o Trunking Theory (pdf, 94 kb)
o Blocked Calls Delayed (pdf, 86 kb)
o Cellular Systems (pdf, 119 kb)
o Other Issues with Cells (pdf, 67 kb)
o Introduction to Digital Modulation (pdf, 139 kb)
o Nyquist Pulses (pdf, 174 kb)
o Geometry of Signals (pdf, 154 kb)
o Other Linear Techniques (pdf, 160 kb)
o Frequency Shift Keying (pdf, 116 kb)
o More on MSK (pdf, 118 kb)
o Matched Filter (pdf, 122 kb)
o Code Division Multiple Access (pdf, 155 kb)
o Orthogonal Frequency Division Multiplexing (pdf, 137 kb)
o Frequency Hopped Spread Spectrum (pdf, 93 kb)
o Path Loss (pdf, 120 kb)
o Diffraction (pdf, 138 kb)
o Log-normal Shadowing (pdf, 160 kb)
o Multipath Fading (pdf, 229 kb)
o Coherence Bandwidth (pdf, 97 kb)
o Coherence Time (pdf, 123 kb)
o Small-scale Fading Distributions (pdf, 140 kb)
o Level Crossings and Fade Duration (pdf, 125 kb)
o Diversity (pdf, 421 kb)
o Equalization (pdf, 128 kb)
