[SOLVED] OFDM BPSK BER Problem
ReComm
Egypt
AA
The following code gives higher BER than the theoretical.
Can anyone help me why? and give me the way to modify the code.
code of BPSK- OFDM
clc;
clear all
nFFT = 4; % fft size
nDSC = 4; % number of data subcarriers
nBitPerSym = 4; % number of bits per OFDM symbol (same as the number of subcarriers for BPSK)
nSym = 10^3; % number of symbols
carriers = (1:nBitPerSym) ;
ep =0;
EbN0dB = [1:15]; % bit to noise ratio
% Transmitter
ipBit = rand(1,nBitPerSym*nSym) > 0.5; % random 1's and 0's
modulated_data = 2*ipBit-1; % BPSK modulation 0 --> -1, 1 --> +1
for ll= 1:length(ep)
for iii=EbN0dB,
k = 1;
for n = 1:nSym
ofdm_symbol = zeros(1,nFFT);
% Map modulated data to FFT bins in OFDM symbol
ofdm_symbol(carriers) = modulated_data(k:k+nBitPerSym-1);
% Time Signal to transmit
tx_signal = (nFFT/sqrt(nDSC))*ifft(ofdm_symbol,nFFT);
% DOPPLER SHIFT
rx_signal1= tx_signal.*exp((2*j*pi*ep(ll)/nFFT ).*(0:length(tx_signal) -1));
rx_signal = awgn(rx_signal1, EbN0dB(iii),0);
% FFT
received_ofdm = (sqrt(nDSC)/nFFT)*fft(rx_signal, nFFT);
% Extract data from carriers in OFDM symbol
received_symbols(k:k+nBitPerSym-1) = received_ofdm(carriers);
k = k + nBitPerSym;
end
% PERFROM DEMODULATION
yF=received_symbols;
yF = reshape(yF,nBitPerSym,nSym).'; % formatting the received vector into symbo
ipModHat = 2*floor(real(yF/2)) + 1;
ipModHat(find(ipModHat>1)) = +1;
ipModHat(find(ipModHat<-1)) = -1;
% converting modulated values into bits
ipBitHat = (ipModHat+1)/2;
ipBitHat = reshape(ipBitHat.',nBitPerSym*nSym,1).';
% counting the errors
nErr(iii) = size(find(ipBitHat - ipBit),2)/(nSym*nBitPerSym);
end
end
Thanks in advance
Here the code :
clc;
clear all
close all
nFFT = 256; % fft size
nDSC = 256; % number of data subcarriers
nBitPerSym = 256; % number of bits per OFDM symbol (same as the number of subcarriers for BPSK)
ep =0;
EbN0dB = [1:10]; % bit to noise ratio
% Transmitter
%for ll= 1:length(ep)
for iii=EbN0dB,
k = 1;
for n = 1:nSym
% DOPPLER SHIFT
%rx_signal1= tx_signal.*exp((2*j*pi*ep(ll)/nFFT ).*(0:length(tx_signal) -1));
rx_signal = awgn(tx_signal, EbN0dB(iii),'measured');
% FFT
k = k + nBitPerSym;
end
end
BPSK =berawgn(EbN0dB,'psk',2,'nondiff');
figure(1)
semilogy(EbN0dB,BPSK,'-bo');
hold on
semilogy(EbN0dB,nErr,'-R*');
grid on
xlabel('EbNo (dB)');
ylabel('BER')
Regards,
Chaker
Thanks for your cooperation
but when i but the next parameter with4, it gives the same error of mismatch
wait your reply,
In your code you generate awgn noise only for one OFDM symbol every time. With only one symbole with 4 carries, your noise can't be considred gaussion.
If you don't want to increase nFFT, you must add noise to a sequence with more than one OFDM symbol.
Regards,
Chaker
