Brownout
Member level 3
Hi gange, when I try to compile systemC and create a .dll for integration into my simulation, I get this in the log:
First it says the compilation succeded, then says it failed. Anyone ever get this before? What is going on?
# Building DLL library...
# ccomp -sc -o "C:/Hardware Projects/cpu_0_data_master_arb_1/cpu_data_master_arb/src/nios_testwrapper.dll" -I "C:/Hardware Projects/cpu_0_data_master_arb_1/cpu_data_master_arb/src/Transactor" "C:/Hardware Projects/cpu_0_data_master_arb_1/cpu_data_master_arb/src/nios_testwrapper.cpp" "C:/Hardware Projects/cpu_0_data_master_arb_1/cpu_data_master_arb/src/nios_test.cpp" "C:/Hardware Projects/cpu_0_data_master_arb_1/cpu_data_master_arb/src/Transactor/cpu_0_cpu_data_master_arbitrator.cpp" "C:/Aldec/Active-HDL 8.3/SystemC/interface/systemc.def" -dbg -D__int64="long long int"
# Warning: C:/Hardware Projects/cpu_0_data_master_arb_1/cpu_data_master_arb/src/nios_test.cpp:32:2: warning: no newline at end of file
# CCOMP: Compilation successful
# Error: Compile failure
