ocean script from unix terminal
sabyasachi.iitkgp
Newbie level 3
ocean script
how to run ocean script files from terminal .
in terminal when i type ocean it shows
ocean: Command not found.
what to do please help
ocean script terminal
At the icfb terminal do this:
load("name_of_the_script.ocn")
What are ocean scripts? Where it will be used?
ocean script
ocean commands are a special set of SKILL commands used to control simulations inside the cadence dfII. you can start simulations or access and plot simulation results ...
hqqh
how to run ocean scripts
Hi
when i type load("name_of_the_script.ocn"),there is an error---->Error:load cant access file name_of_the_script
so what the problem???
pllllllllllz help
thanks in advance
unix running script inside a cript
type the following in the CIW:
load("/.../name_of_the_script.ocn")
/..../ stands for the absolute path of your ocean scripts.
skill commands in ocean
thanks for ur reply
i tried that but the same message appears
i dont know why???????????????????
Added after 24 minutes:
ohhhhhhhhhhh
i know my error
i wrote oceanscript.ocn not oceanScript.ocn
thanks again
oceanscript +plot to file
Hi
can i write expressions in ocean script to calculate efficiency?
thanks in advance
ocean script errors
Hi
All question about Ocean should be resdirected to Custom IC design branch
Any way, Ocean supports two ways to run SKILL (Ocean is one of few SKILL libraries ) based through command line
1. ocean -replay my_scripts.ocn
2. ocean < my_script.ocn
Be careful when you use the second way. The "exit" command should be put in the end of your script. Otherwise your Ocean session does not finishes and you will have to finish it manually.
P.S. Please use 'which ocean' shell command to check if you set your enviroment correctly.
setenv PATH $CDSHOME/tools/bin:${CDSHOME}/tools/dfII/bin:$PATH could help
Added after 10 minutes:
BTW
Often you do not need to have MMSIM tool for spectre-based similation or for any manipulations with already simulated data.
But if you would like to start Spectre-RF similation you should to include path to MMSIM binaries to you enviroment PATH variable. Please do not be surprised if you face 'ocean' binary in MMSIM installation hierarchy, the fact is MMSIM contains large part of dfII hierarchy from Virtuoso (icfb in previous released), just duplicates it :) for case when a customer do not have Virtuoso tool but have only MMSIM tool.
Re: ocean script
Hey, OCEAN is a Candence tool to run the simulation scripts, so first run Cadence, and then write 'ocean' in the terminal, it will work!
Thank you
I'm running a ocean script form unix terminal, not from icfb. The simulation creates a waveplot, but after the simulation ends, the plot disappears. How do I stop it from disappearing?
Thanks in advance.
