ocean question: eval undefined function
Julian18
Full Member level 3
Full Member level 3
Hi, all
when i run ocean script, it says:
*ERROR* eval: undefined function - ocnWaveFormTool
*ERROR* load: error while loading file
what 's the problem here
Thanks
i think u r defining wavescan or awd at the first of teh command try remove this line
Hi safwatonline
Yeah, this command defines the graph tool you want to use, but why can not the ocean know this command, I mean, whether should I add some environment variables to solve this.
Thanks
well, i am not sure what is the problem but i think removing the line will solve it , usually ocean will use the default wave viewer which is most probably the one you want (the one you are using in cadence)
yes, when i removed the first line, i can load the ocean script, but at this time , i can not use graph command to plot picture (addWindow() etc.).
